efb
i bought the efb and i install it. i get a black screen when open it in vc cockpit
  • Sorry, to ask such an inane question, but do you have the 1.026a patch installed since it requires it?
  • edited February 22
    yes i have the patch installed
  • edited February 23
    I also get a black screen when I open it. Yes, 1.026a is installed.
    And, when I run it outside the simulator on a tablet using "http://{local ip address}:8782/index.html", it runs but gives a "TypeError: Failed to fetch" error message ... ie, no data is imported and the fields are all blank.
    Intriguingly however, it works perfectly fine when I run it in my web browser on the local PC with the sim.
    MJC84-EFB
  • Kindly contact us via our support email so that further trouble shooting can be done.
  • @kroswynd I work in IT Customer Support and we have had something similar happen to clients of ours ...
    Based on this, it occurred to me that I use a static IP address on my PC and the fact that the "serverurl.js" file uses "localhost" may be cause of the issue. So, I manually modified the "serverurl.js" file and changed "localhost" to the actual static IP address used by my PC. The EFB now works perfrectly outside the simulator on my tablet. (I note there is no such IP address or "localhost" used in the EFB.ini file and therefore no change was required there.)
    However, despite this change in the "serverurl.js" file to the actual static IP address used by my PC, I am still getting the black screen when I open it within the simulator itself.
    I will investigate this a bit further later today and will contact you via your support email if those investigations don't get me anywhere.
  • Sounds good. Thanks for additional input, but be sure to reach out to us in Support in case there is anything else that may be amiss.
  • edited February 25
    UPDATE:
    I have run various experiments and tests and have been unable to get the 2D EFB panel to work. In other words, I am still getting the black screen when I open it within the simulator itself.
    The relative path in the panel.cfg file does look to be correct and the index.html file does run perfectly if I simply double-click on it. But, it's not working from the 2D panel menus in the simulator. So, for testing, I decided I would try moving the index.html file to different folder locations and/or move the entire EFB folder, and then subdequently change the path information in panel.cfg to match accordingly. Despite this, nothing I tried worked. I used relative paths, absolute paths, paths with quotes, paths without quotes ... the simulator's root folder, MJC8's root folder, MJC8's panel folder ... etc etc.
    The impression I am getting, rightly or wrongly, based on this testing, is that it appears that even though the path information in panel.cfg is correct (well, I hope I am entering that correctly :smile:), the simulator is simply refusing to run/load the index.html file. And this, despite where I try moving/locating it to. I couldn't even get it to run/load the help.html file.
    Changing the window_pos= parameters within panel.cfg did move the black screen around on the main screen, so I know it's looking at the right location within panel.cfg ... but, as to why it won't load the index.html file, I simply don't know.
    (Hmmm, a thought bubble ... as a user of P3Dv4, could it be that HTML_FILE= is not a valid parameter option for panel.cfg within P3Dv4? Is this perhaps a parameter option only introduced for P3Dv5 and higher?)
    But, all of that said, at this stage, I am not unhappy. I doubt I will ever want to use the EFB as a 2D panel anyway ... so the fact that the EFB does work for me locally in my web browser and also now works outside the simulator on my tablet after I manually made the IP address change within the "serverurl.js" file as mentioned above in my previous post ... I am happy. Based on this, I didn't feel it necessary to lodge an email to Support.
  • edited February 26
    freddy,
    HTML_FILE is a valid keyword according to the P3D v5 SDK:
    https://www.prepar3d.com/SDKv5/sdk/panels_and_user_interface/panels/panel_configuration_files.html
    For P3D v4 this keyword is not documented in the SDK:
    https://www.prepar3d.com/SDKv4/sdk/panels_and_user_interface/panels/panel_configuration_files.html
    So this will be the reason, why it is not working for you.
  • aua668,
    Ahh. Yes, the behaviour I was observing with my testing certainly suggested that "HTML_FILE=" was not being recognised by P3Dv4. So it is indeed exactly as I thought.
    I am willing to bet that the original poster in this thread, TBT47, is also running P3Dv4.
    Thanks for the confirmation/clarification.
    And, as I said above, I am still happy. The EFB is running externally on my tablet (after I made the easy manual change in the "serverurl.js" file), and it's also working locally in a web browser ... and both of those will suit me just fine!
  • @Freddy,
    I just purchased the Q400 EFB and am having the same issues. I am trying to open the EFB as a kneeboard page but am having a bit of a struggle. The page will display but it doesn't seem to import data. Any advice on making this work?
    Cheers, Jax
  • On which flight sim version ?
  • Sorry, I should have edited my previous post and given much more information. I'm still using P3dv4.5. I remember FSX being able to view webpages on the built-in kneeboard. I'm guessing LM removed that old code for something more robust.
    I am able to see the EFB on the built-in kneeboard but I keep getting a script error popping up.
    I do have it working in a web browser (Firefox) as designed, so it's all good.
    Cheers Boss, and Thank-You for the EFB.
    Jax
  • edited April 21
    Yes, as Boss asks, "on which flight sim version"?
    And, when you say you are trying to open the EFB as a kneeboard page, can you elaborate on that? Are you specifically trying to open it in the virtual cockpit, or on a tablet, or in a web-browser?
    If you are trying to run it in the virtual cockpit in P3D v4.5, then, as per the discussion in this thread, it won't work and you'll just get a blank, black window ... hence the question "on which flight sim version"? For virtual cockpit use, you'll need to be running P3D v5.0 or higher.
    If you're running it in a web browser or on a tablet, and your PC uses a static IP address, then you will need to manually edit the EFB's "serverurl.js" file and change "localhost" to be the IP address of your PC. If you don't do this then it will run but will probably be displaying a "TypeError: Failed to fetch" error message ... ie, it's failed to import data. (And, I will guess that you'll get the same error message in the virtual cockpit even in P3D v5.0 or higher if your PC has a static IP address but the "serverurl.js" hasn't been manually updated/edited to reflect that.)
  • @Freddy, for some reason my response to Boss wasn't showing up in the thread. It is showing now however. The sim is P3dv4.5 and I was attempting to use the built-in kneeboard to show the Q400 EFB. I did have some success as far as getting the EFB show up, but continue to get scripting errors which block any real functionality of the EFB.
    Freddy, I did read your posts on the matter and it is thanks to you that I was able to get the EFB working on my web browser, so Thank-You so much for your expertise.
    Cheers everyone, Jax
  • edited April 22
    Ahhh. I am glad my observations and subsequent posts were helpful for you and that you managed to get things working on your web browser. ๐Ÿ‘
    As for the scripting errors you mention, that's not something I am experiencing or have any ideas about. Hopefully Boss or kroswynd will be more help for you there. :smile:
