P3Dv5 HF2 and 1.021
Hi there,
P3Dv5 is loading the scenery, then the plane ... And then close and goes back to desktop.
- No error message.
- Installed in P3Dv5 folder
- Same behavior if load a default flight with a default plane
Any idea ?
Thanks !
oliver
It seems to happen when view is changed.
inside to outside -> P3D crash and exit
outside to inside -> P3D crash and exit
With ChasePlane or not -> P3D crash and exit
I've just installed the patch. No more CTD when loading the plane ... Thank you !
You're welcome ... It's nice to say when all is ok too !
patch for PRO v1.021 available separately?
There will be a patch available in the user area shortly for the blank panel issue for the syspan.
