WX Radar freezes sim
Hello. every time i turn on the WX the sim freezes and or crashes with no log about what's causing it. running on P3D 4.3 and W10
  • Are you by any chance running sky force as your weather engine generator?
  • Don't use it for weather but for cloud models
  • Once I'm home I'll give it a try without skyforce and see.
  • Tried without any wx and still freezes the sim. Anyway I'm doing a full windows install soon I'll see if i run into the same issues.
  • A full install should not be required. Have look in your mjc84.ini at the beginning there should be a line WXAR=1. Change that to 0
  • Ok. Will try that. Wouldn't that completely disable the wx radar?
  • There are 2 switches for weather radar, one is for Active Sky and the other is for REX products which is still a work in progress.
  • Where can i find that?
  • The "ini" folder which is located in you mjc8q400 folder will contain the following lines:?
    [INTERFACE]
    JOYSTICK_INTERFACE =1
    ASN_INTERFACE=1
    WXAR_INTERFACE=0
    ASN_INTERFACE=1: enables the uses of Active Sky (if you use AS4 or AS Next then you need this enable
    WXAR_INTERFACE=0: Should be the switch that should be disabled (set to 0)
