WX Radar freezes sim
Hello. every time i turn on the WX the sim freezes and or crashes with no log about what's causing it. running on P3D 4.3 and W10
Are you by any chance running sky force as your weather engine generator?
A full install should not be required. Have look in your mjc84.ini at the beginning there should be a line WXAR=1. Change that to 0
There are 2 switches for weather radar, one is for Active Sky and the other is for REX products which is still a work in progress.
Where can i find that?
The "ini" folder which is located in you mjc8q400 folder will contain the following lines:?
[INTERFACE]
JOYSTICK_INTERFACE =1
ASN_INTERFACE=1
WXAR_INTERFACE=0
ASN_INTERFACE=1: enables the uses of Active Sky (if you use AS4 or AS Next then you need this enable
WXAR_INTERFACE=0: Should be the switch that should be disabled (set to 0)
