Oh in that case you are correct, misunderstood your first post. The visual package is a separate (optional) package for purchase which we released last year.
For some reason I read it meaning that you had purchased the visual enhancement package.
Engine failures are designed ONLY for the TRAINING & COCKPIT Editions. If you are a PRO user then you have to build your own scripts as engine failure by design are not a part of the PRO Edition.
Could we get engine failure scripts to cut an engine off at a desired Indicated Airspeed instead of Groundspeed? I had to post on this forum months ago asking for someone to fix the script, and they best they could do was to get it cut an engine off at a desired True Airspeed, which is closer, but still not perfect.
Bought the visual pack, a great improvement thanks. BUT before you buy it, decide if the Training Version is for you first! The reason I say this, the Visual Pack at Just Flight is £19.99, the upgrade price for the Training Version which includes the Visual Pack is £40. So in real terms, you pay only an extra £20 for the Training Version. Wish I had realised that as would have gone for the Training. Keep up the good work!
Hope someone notices this post as I realise it's an old thread, but I only just came across it.
At the top it says that the package has been released for version 4 and 5 (admittedly this was 1½ years ago), but on SimMarket it is listed for P3D version 5.x or 6.x. Does it run with P3D V4.5 (which is the sim I fly) ? If it does I will most likely purchase it.
Have you contacted the vendor to discuss the issue? That would be the first place to start.
Yes, and was told its a separate package that need to be bought..
My apologies.
Scripts: Added missing engine failure scripts
@noabergstrom
Missing engine scripts???
Any update on the Q400 for MSFS?
We'll be sure to provide one when we see it fit to do so. Lots of moving parts at the moment.
Hi. Does it work with Training Edition?
Best,
Keith
It was originally released for P3Dv4 and P3Dv5, so it should still work for P3Dv4.
Thanks !
